5. August 20251 J. Hi from the UK...I am in the process of rebuilding my ZPJ4 cylinder heads...on removal of the tappet saddle & the tappets themselves I had to force some of the ceramic,s with a prybar they were so tight...I take it this is not normal...has anyone had the same problem & what did you do to fix the problem. Cheers Mutly.
8. August 20251 J. Hallo, die Keramik sitzt im Stößel Bombenfest, das ist so richtig Warum hast du sie entfernt?
